9v1 zener ??
Started by idgit, May 25, 2013, 07:25:12 PM
idgit
Building a Albert Hallish type and Z1-3 are 9v1 Zener.  does this mean that I can only use 9v power supply?
what if i chose an 18 volt Zener  http://www.mouser.com/ProductDetail/Vishay-Semiconductors/BZX85B18-TR/?qs=sGAEpiMZZMtQ8nqTKtFS%2fKE3JtglsWdk7c5jyomIMnE%3d
thx?
The zener will limit the input to 9.1v by conducting voltage over that threshold. This is to keep the MOSFETs from blowing up.
Besides, it's a distortion pedal. Giving it more voltage will make ... Not distort as much.
idgit
Thanks for responding..
I'm asking because a certain commercial maker of this pedal builds them for 9v-18v operation.  18v giving more headroom and punch, like an amp...no?  perhaps they  use something other than mosfets?
Quote from: idgit on May 25, 2013, 08:08:38 PM
You're not going to get 9v on the gate of the MOSFET by using an 18v supply. That's not what I was referring to. Try googling 'MOSFET static protection' -- MOSFETs have a particular weird issue.
My second paragraph is just something I feel compelled to tell people when they want to feed a distortion pedal more volume ...
idgit
Thanks again, I'll build as spec'd then perhaps look into modding it later
Quote from: idgit on May 25, 2013, 08:22:43 PM
Okay, but to be clear, you can't mod it to use an 18v Zener in those positions. It would fail to sufficiently protect the MOSFET. The diode has 0 effect on the sound.
