Noob Solder question
Started by PhiloB, May 17, 2013, 11:54:17 PM
rullywowr
For a tip cleaner, I used to use a sponge but I found you can get a copper scrubbing pad (most likely at the dollar store) and it works great!  No water required and it cleans your iron tip with just a quick poke into the copper pad.  I attach mine to where the sponge would normally go with an alligator clip or two.
das234
Quote from: rullywowr on May 20, 2013, 06:17:14 PM
I concur.  My Hakko iron came with both the sponge and the brass scrubby and I hardly ever use the sponge, just the scrubby.
I use the tip cleaner / tinner and then brass scrubby. Sometimes the tip gets dull and it doesn't heat evenly and this brings it back to life.
TNblueshawk
John
