multiplex modulation question
Started by hoodoo, May 09, 2013, 11:53:27 AM
hoodoo
G'day to all, Matt here. I was hoping that Josh or anyone else with good advice could answer a question i have in relation to hooking up the positive and negative pads on the modulation pcb. Where is the best place to attach these to. I am using one of Josh's 3pdt boards ( old style ) that doesn't have the extra pads. Would i connect them to the dc jack and then go from the dc jack to the 3pdt board or is there a better way to do this, thanks, Matt.
Parra
Hi, i think i connected mine directly to the 9V power jack and i had no problem with noise. You can also solder the negative (ground) to your ground point (normally people use the imput jack as a star ground point), and the positive (9V+) to the power jack.
Hooking it right up to the 9V jack is fine.
Josh
hoodoo
