Hipster - sub for 25k trimpot?
Started by gomer, May 05, 2013, 06:18:02 PM
gomer
I've got a 20k and 30k, so i tried the 30k, and i get signal but no fuzz. do i have to use a 25k trimpot? or should i try the 20k?
You should get fuzz just not as much with the 20 and too much with a 30,you may have another issue
gomer
strange , with bias adjusted all the way one direction I get no signal, then as u turn it the it acts like a volume. I'll go over all my parts and see if i made a mistake.
thanks jimi
The trimpot is simply a variable resistor. As you increase the resistance between 9v and the collector of a transistor, the voltage at the collector decreases and the gain goes up.
Using a 20K or 30K there should not make a difference; you are actually looking for something pretty close to 5K-15K, so there's plenty of range on either side of the trim pot. In fact, if you're using silicon transistors, you would have a working pedal just sticking the trimpot in there and setting it in any old position, just maybe not a good sounding one ...
If you're not getting any fuzz, something else is wrong. You need to check the orientation of the transistors, take voltages, etc.
gomer
well i switched trans to 2n5088 ( originally had bc109) and the pedal seemed to work more like it should so i guess i need to play with different transistors.
thanks for the reply ya'll!
Quote from: gomer on May 06, 2013, 12:08:18 AM
Hm. Double check the pinout on your BC109; make sure you had it in right. The little tab faces away from the trimpot (it's the emitter).
jimmyjazz
Bman40
I just finished one yesterday with a 20k trimmer... seems to work fine.
BK
