Mudbunny = Mad Professer Fire Red Fuzz
Started by VooDOOM, January 10, 2011, 02:49:23 AM
VooDOOM
I've been reading that this is a muff variant and was wondering if the Mudbunny pcb could be used? How does the mudbunny pcb compare to the gruntbox pcb? check out the following links.
http://www.buildyourownclone.com/board/viewtopic.php?f=9&t=25373
http://www.freestompboxes.org/viewtopic.php?f=7&t=9319&start=40
thanks for any reply. ;)
stecykmi
it's seems to be pretty close. A quick glance suggests the last gain stage on the MP fuzz has a cap+resistor in parallel with another resistor, while the Mudbunny has only a single resistor. And the MP uses diode connected mosfets for clipping in the 1st clipping stage while the bunny uses actual diodes.
If you could figure out a way to squeeze those in, you'd have a clone after some part value substitutions, i think.
