what tubes bugera v55(non-pedal)
Started by garfo, April 28, 2013, 02:36:28 PM
Aentons
Quote from: Zerro on September 26, 2021, 11:37:28 PM
BTW, can anybody from USA tell me WTF is that "mojo"?
It's a special voodoo magic luck charm
Zerro
Thanx, now I can finally die without feeling of guilty...
thesmokingman
Quote from: redkurn on September 26, 2021, 07:07:23 PM
How did it turn out? I have the v55hd infinium.
I've been looking into changing v1 to a 5751 or 12at7 as suggested above.
Did you change any other tubes from 12ax7 and are you using 6L6 or find a alternative?
I'd give two configurations a try: 2 12AY7 into a balanced 12AX7 PI and keep the 6L6s OR 3 x 12AX7 into 5881s (rebiased, of course)  ... if it were a head instead of combo I'd probably opt for the long plate 12AX7s and the 5881s
redkurn
Quote from: thesmokingman on September 28, 2021, 06:53:19 PM
Mine is just a head, V55HD.
The Infinium is supposed to automatically bias the tubes, would I need to do any mods to make the 5881 tubes to work in place of the 6L6?
As far as I know only the power tubes are biased automatically, the only two that have an LED on the back of the amp.
thesmokingman
