Kingslayer... No switches... Do I solder a jumper??
Started by rydog2223, April 27, 2013, 02:14:32 AM
rydog2223
Hey guys!  I'm opting not to do any switches with my Kingslayer.  Do I have to solder a jumper wire in the clip holes on the PCB board or leave them open?  Thanks so much guys!!!:)
Yes; without the jumpers, the diodes will never be connected to ground. Use your multimeter to check continuity to make sure you jumper the right pads.
rydog2223
Quote from: midwayfair on April 27, 2013, 04:32:01 AM
Thanks man!  So there is no hard and fast rule about what pad to jumper? Thanks again!
