zero point sdx help
Started by garfo, April 20, 2013, 07:44:58 PM
garfo
Hi, I've bulit my sdx and it works, but it's weird, only position two of the rotary switch puts out delay.On the other ones it will only make one repeat if the  Path switch is turned on.I experimented removing the lock from the rotary switch and I can find two more places where delay occurs, but I don't think this is the way it is supposed to be and they don't sound that different from each other either.
garfo
Well.I think I found out why.... :PP
The thing is I believe the 3p4t switch was soldered the other way arround.How should it look like once it is mounted,should I be able to read the numbers and the letters on the pcb??????
Quote from: garfo on April 20, 2013, 07:44:58 PM
pierre67
Hi Garfo !
I guess that you have soldered the rotary switch to the wrong side...take a look to the ZP build guide :
http://www.madbeanpedals.com/builds/reports/zpsdx/index.html
good luck  ;)
garfo
Indeed Sir, I'm afraid that's what happened.
Now I've broken the switch while trying to remove it...oh damn, these boards are sturdy as hell... :)
Quote from: pierre67 on April 20, 2013, 10:19:21 PM
Hi Garfo !
good luck  ;)
