How to cure weener scratch?
Started by octa805, April 03, 2013, 05:28:02 AM
octa805
Love my weener (that was fun to write) but its still got a bit of scratchy noise towards the treble end. How do I get rid of this?
Some say bumping up R2 from 220ohms would work. Others say R4? Or could it be a bad pot? If so, how could I tell?
I just built another one to similar specs and it is totally quiet. Biggest difference are R4 and the trannies.
Any ideas would be great. Thanks
octa805
jtn191
So there's a static noise on the treble end? 1st try low gain, low noise transistors.  Like 2n222a
I had the same problem with my cry baby-based build and saw a rumor on diystomp that noise is reduced if the hfe of both transistors is closely matched. I tried it and it seems to help!
I had that issue with a vox wah just today. The cure for this one was tightening the pot. when I got to the treble end,the pot was twisting and touching the bottom of the wah plate which is metal.
octa805
thanks dudes
I've swapped Q1 out a few times and only noticed volume differences more than anything with the static noise persisting throughout.
I'll try some others I just got in along with ratcheting around the trimpots I have in R4 & R5 (I believe that's where they are off the top of my head)
THanks
danwelsh
How to cure weener scratch lol.....thats just haha funny. All jokes aside glad u figured it out
icecycle66
frankie5fingers
I saw one on weB MD asking how to cure Weener itch.
Funny thing is the replies were pretty much the same....
octa805
Still working on this one
I need to swap out R4, socket it and see if that does it
I've tried a lot if tranny swaps and so far no real change in static. Just volume mostly
Stomptown
Quote from: octa805 on April 04, 2013, 03:25:08 PM
annoying bump
Weener scratch AND an annoying bump? Dude, it's time to go to the doctor!   ;D
octa805
Hi Everyone,
Just wanted to follow-up here cause I finally fixed this.
I thought I'd have to play with R2 or R4 so I swapped those around a ton. Did nothing.
Then I finally just sprayed some de-oxit spray in the sweep pot, worked it around a few times and then amazingly it was 100% clear. NOT ONE BIT OF STATIC.
I don't know what boogers were in there but it was pretty sweet to finally clear that up with such a simple thing.
Now my wah is perfect. yea!
TNblueshawk
Looks like I'll put this one in my "should have been obvious" folder that I've built up for myself over the years  :-[
John
aballen
Thsi should take care of your weener itch, um I mean scratch.
http://www.antimonkeybutt.com
