LED array question
Started by slimtriggers, April 02, 2013, 02:36:57 AM
slimtriggers
I put 3 white LEDs in series.  The online CLR calculator I normally use is telling me this is not possible with these as the voltage drop is greater than the supply voltage (9 volt 1Spot).  Of course I did it anyway, and put a 120r resistor in line just in case.
The LEDs are working fine, but the pedal isn't working now.  Have I starved the circuit for voltage with my massive light show, or should I look elsewhere for trouble?  I rocked it before boxing and it worked great, now I'm only getting bypass signal ???
Quote from: slimtriggers on April 02, 2013, 02:36:57 AM
Did you disconnect the LED's to see if that fixed the issue? Also I've found in these situations that I would sometimes ground the leds out on the enclosure which would make the effect stop working also.
slimtriggers
I think I'm gonna have to break down and try that.  A quick probing with the DMM and there's apparently no voltage going to the circuit.  I think I'll hit it tomorrow, though.
Thanks for the suggestions, Jimi  8)
slimtriggers
Ha!  A lifted trace-the 9v pad had come up.  When I started probing around I had 9v up to there but nothing anywhere else.
Soldering iron is heating up now.  If it works I'll have a build report up today :)
slimtriggers
The LEDs ending up being OK.  It doesn't effect the circuit at all.
I had a lifted trace and my NOS BC109 took a dump.  Replaced it with a BC109 from Tayda and it fired right up 8)
