is that a wrong wiring?
Started by venom02, March 30, 2013, 01:53:06 PM
venom02
Hi everyone. I'm trying to build a devi ever Hyperion 2 clone but it doesnt work well. i'm getting a continuous loud signal as output and the guitar seems doesnt effect it.
here's the board schematic
and here's how i wired it offboard (its ugly but i hope clear to read)
(omitted the 2,2k res soldered to the LED)
I triple-checked the board and it's correct. where could it be the problem? many thanks
Check for solder bridges around the cuts and between the strips
venom02
Quote from: jimilee on March 30, 2013, 03:22:35 PM
checked and nothing is bridging. here's a pic, the marks between strips are cutter passages to be sure the is nothing between.
the problem is still there: a loud sound modulated by the INT pot while the volume and OSC pots seems do nothing or very little.
If not powered on the guitar sound is pretty and clear (so the bypass is working well)
hammerheadmusicman
Perhaps i'm wrong, but, that looks like a bridge to me..
I circled the bit in Red.
Good Luck
George
I play Guitar, and Build Stuff..
venom02
no that solder is not touching the strip beneath. its just the view angle of the picture that makes an illusion ;)
Ok so, what type of loud signal, and are you getting any guitar sound at all?
Also, your dc jack doesn't appear to be grounded to your input jack
2tonewarrior
You have grounded oscillation 1 not 3 ;) hope this helps
venom02
Quote from: jimilee on March 30, 2013, 06:32:45 PM
uhm now i see you're right, my DC jack is not grounded to Input, thanks. i will fix it and thell if that has resolved the problem.
Quote from: 2tonewarrior on March 30, 2013, 08:36:19 PM
that will only change the rotation of the pot from clockwise to counterclockwise ;)
venom02
well, still not resolved the issue. now i the VOL pot seems to work correctly but the noise hasn't gone and the guitar is not hearable almost at all as before
now the wiring is this, addedo ground IN to ground DC
look up the mbp standard wiring pdf, it's what we all use pretty much, edit, here it is I found it.
http://madbeanpedals.com/tutorials/downloads/StandardWiring_MBP.pdf
venom02
#11
Checked using your PDF but it seems exactly like my wiring diagram :(
Just to be pedantic... the image in the OP is NOT a schematic, it's a layout.
Quote from: venom02 on April 01, 2013, 12:54:44 AM
Except you have a volume lug hooked to the stomp. That's a strange layout for sure. I'm still trying to figure it out myself. Also osc 3 should go to ground and you have 1 going to ground.
jolly1423
^The in's and out's of the board run through the pots so according to the layout that seems to be right...
