Tiny toggles?
Started by midwayfair, March 15, 2013, 06:50:57 PM
I like the mountain switches (and their cheap clones), but I've been searching for something appropriate for tight spaces, especially something short enough on the inside that I can fit a PCB on top in a 1590B. Does anyone have a part number or link?
Smallbear has some tiny pin mounted On/On SPDT's. I just got a few. However, they may not work well in all situations. If you are using 16mm PCB mounted pots they might be too small.
I have gotten my hands on similar DPDTs but I don't remember where, unfortunately.
frankie5fingers
Jon, these two are from Surplus Electronics Sales
http://www.surplus-electronics-sales.com/index.php?main_page=index&cPath=59
58    280-1059    SPDT Toggle Switch, Center-Off
Small black center-off SPDT toggle switch. Fits in 15/32" diameter hole. Has three small (20-22 AWG size) solder lugs. Low voltage and current...
   $0.50
536    280-1062    Toggle Switch, Sub-Miniature
Toggle Switch, Sub-Miniature Sub-miniature toggle switch with hardware. Bushing Diameter: 15/64" Height: 1-3/8" Switch Width and Depth: 33/64" 6 A...
Quote from: nzCdog on March 16, 2013, 03:46:55 AM
Effects connection carry the small toggles, I've used them they were good
http://www.effectsconnection.com/oscommerce/index.php?cPath=1&osCsid=c679f64666da863de29ab24c07ca4f33
Those are short bat -- is the body of the switch actually smaller, too?
EC has absolutely deadly shipping, but if I'm getting 20 switches that make a lot of builds easier, it would be worth it.
Quote from: frankie5fingers on March 16, 2013, 03:12:43 AM
   $0.50
Whoa, these look seriously cool:
http://www.surplus-electronics-sales.com/index.php?main_page=popup_image&pID=636
Thanks for the tip!
Haberdasher
#7
ledswitch has some pretty small subminis.  whether or not they will fit under a pcb I don't know.
http://www.led-switch.com/Sub%20Miniture%20Toggle%20Switch.htm
FABBED PCB's FOR SALE:
Now carrying Matched JFETS
DutchMF
How about these: http://www.banzaimusic.com/Low-Cost-MINI-SPDT-on-on.html ? Shipping to the US would be quite costly, I presume, but I can help with that if you like.
Paul
frankie5fingers
Quote from: midwayfair on March 16, 2013, 04:16:28 AM
   $0.50
Thanks for the tip!
FWIW, they're sturdy too; I've used them a few times.  At half a buck a throw (no pun intended) you can't go wrong.
