Waterslide decal problems
Started by gtr2, December 28, 2010, 12:48:46 PM
Finished the decal and polycrylic clear coat!  Thanks again for the help!
The blueish haze must be from the flash..
Josh
crashguitar
Looks nice and clean. Can't wait to see the finished pedal.
tenwatt
Quote from: eniacmike on December 29, 2010, 03:18:05 AMI never clearcoat before I put it the decals on, always after.
Are you saying you never put a clear coat on the decal as the instructions suggest?
Not too bright....
You need to clearcoat the decal before applying only if you are using an inkject printer or the ink will run.  It's not necessary with a laser printer.
