AquaBoy issues..
Started by yurka, December 26, 2010, 09:54:34 PM
yurka
Built two of these side by side, having the same issue for both. Iv checked the wiring over and over again, I am confident it is correct, when the effect is switched on, signal does pass, just no delay, and knobs don't do anything either. Source voltage on the V3205 is right under 8V, all other ICs also getting good source voltages. I was wondering if anyone could post the proper voltages for all the pins on the V3205.
Are you using a v3102 clock?
jiffy
You have moved the trims right? There's just a small section where the delay turns audible on one of the trims.
yurka
Yep, iv messed with the trimmers, no luck. And yes,  i am using the V3102 clock.
jiffy
#4
Check in particular the depth pot? An error there could result in no delay.
