Sonic Screw Deux
Started by pickdropper, March 02, 2013, 05:02:14 PM
This is similar to my other Screwdriver build as it uses the same artwork.   I really wanted a Sonic Screwdriver build with that artwork in a Tardis blue enclosure.  :-)
I decided to post a build report anyway because I did a different PCB layout for this one.  On this build, the only through-hole part is the Germanium.  I swapped the BC109C transistor at Q2 for a SMT 5088.  There are other options as well, but I haven't tried other trannies there.
It sounds very similar to the original Screwdriver, but this build is a touch more aggressive and has more low end.  Still deciding playing with the settings in comparison with the standard screwdriver.
monkeyssj1
how do you do it!? you're a machine!!
pryde
Stunning.
"DIY Master Builder" on your avatar is dead-nuts correct  8)
Dave, how do you keep the transistor from shorting on the top? Does the board sink in more than it looks like in the pictures?
(Beautiful as always, by the way.)
Haberdasher
FABBED PCB's FOR SALE:
Now carrying Matched JFETS
Quote from: midwayfair on March 02, 2013, 06:59:15 PM
It actually doesn't hit.  I wasn't totally sure until I put the lid on, but apparently there is some clearance.
If it had hit, I would've thinned out the top on a mill until it was clear.
soldersqueeze
Ughrr... that's so pretty and Doctor Who themed... I need to save up and convince you to sell me a pedal. All your work is beautiful.
Stomptown
Beutiful work! The blue paint looks great with the laser etch.  :o
Thanks for the kind words everybody.
That's incredible.how did you make The bottom fit on with that big old cap sticking up?
Quote from: jimilee on March 04, 2013, 04:21:58 AM
It's the Ge trans, and it doesn't stick out as much as it looks like in the photo.  It is only 0.075" above the bottom of the case.  Since there is a recess in the lid, it doesn't actually hit.
wolfingsworth
This is none other than a work of art! Once I get a few builds off of my to-do list, I'll start populating my SMT board with those itty bitty components.
Side note: does Mouser carry the correct 9mm pots?
Quote from: wolfingsworth on March 04, 2013, 06:01:25 AM
Yes they do, but they are more expensive there.  I prefer to get them from Small Bear.  Mammoth has some as well, but not my preferred type.
