2 effects in 1 Switching HELP
Started by MullisMan, December 18, 2010, 03:17:01 PM
MullisMan
I've built a Zendrive and SHO clone and put them in a 1590BB enclosure.  I wired them up as shown in this topic from freestompboxes:
http://freestompboxes.org/viewtopic.php?f=48&t=8216
The guitar signal comes in, goes to the first switch which is the Zendrive, and then to the SHO, and then to the output jack. The problem I'm having is that I don't get any dry signal coming through when both effects are disengaged.  To get any sound, I have to engage the SHO, and then if I engage the Zendrive I can hear that as well, but not vice versa (Zendrive engaged only).
I'll include a gutshot to see if that helps, the big board in the middle is the Serendipity board, and its footswitch is to the left. That board hides the red wire going from the output lug of the first switch to the input lug of the second switch.
Any suggestions?
[attachment deleted by admin]
Can't really tell anything by the picture.
Check thishttp://www.madbeanpedals.com/projects/Krankosaurus/docs/Krankosaurus_ver3.pdf out
It's basically 2 boards combined in one just use the in outs accordingly...
MullisMan
That did it, the wiring diagram I used in the other thread doesn't work.  I'm just used to wiring up 3PDTs with gauusmarkov's method, so I wanted to go that route.  Madbean method from here on out though.  Thanks for the help!
