Weird power issue
Started by irmcdermott, May 02, 2010, 05:39:57 AM
irmcdermott
Haven't had this happen before and not sure what to check. My pedal runs off of a battery no problem, but if I plug a power supply into it powers down. Not sure what is going on. Thoughts? Thanks!
gmr1
Quote from: irmcdermott on May 02, 2010, 05:39:57 AM
you prob. have your tip and ring of the power jack wired backwards (battery is on the lug that should be going to board +9v, and visa versa)
irmcdermott
DOH! think you're right. thanks! going switch them around and check that. thanks again!
