Deep Blue Delay with Active Pickups?
Started by LaceSensor, January 17, 2013, 11:14:38 AM
Hi
I build a DBD for a friend, using the sea urchin pcb
he is complaining that it has no delay just a high ;pitched squeal, so he posted it me back.
I assumed in postage something had happened, or he had fried something.
Get it back, unpack, works just fine.
Can only assume its his pickups?
Anyone with experience on this?
thanks
marmaliser
Could it be his power source ?
I have 2 DBD's at home and will test them tonight with my EMG's (81/60 set)
wierd thing is he said it did the same with battery as with 9v adaptor.
works just great back with me on both...
so wierd. only thing I can think its his guitar...
GermanCdn
I built the sea urchin and it did not play nicely at all with my EMG loaded SG.  Some distortion and general unpleasantness.  Passives worked fine.  Solved the problem by getting rid of the EMGs.
annoyingly, I know the issue now. It was a low battery and wrong PSU
ran the pedal on a battery putting out 6v and it behaves with a high pitched whine which increases with the mix turning up....
marmaliser
Quote from: LaceSensor on January 17, 2013, 04:37:15 PM
Bazinga :)
