Blending a split signal
Started by insomniac2295, January 10, 2013, 07:45:11 PM
insomniac2295
So, I want to incorporate the dry out on my
Micro POG into my pedalboard setup. Basically, it has an effect out and a dry out. I want to send my dry signal to my distortions and then blend the effect out from the POG with the post-distortion dry signal. Make sense? I need help in figuring out how to do this.
What you're really looking for is a mixer. A mixer will take a set of signals and then 'blend' them or mix them down into mono.
marauder
Build a Paramix, put the wet signal from POG into the input jack, and dry into your dirt boxes, and then into the loop return of the Paramix.  Or,  POG and dirt in the loop of Paramix.
Lots of options with this versatile little circuit.
jeffaroo
guitarpcb.com has them
ask jimilee he just finished one
Not enough germaniums in this world to complete my wish list !
In addition to an effects loop,the Paramix now has inserts that will make that possible.check it out
It's my understanding that the inserts will add another effect back into the signal post mixing stage, it all sounds very cool. I am just about done with my second run at this bad boy.
