Retrograde "pumping"
Started by Vallhagen, December 25, 2012, 06:45:45 PM
Vallhagen
Hi!
I am just finnishing my retrograde; i am running the fully populated PCB at my test setup.
*) The circuit seem to work as it should, but it is "pumping" when i play staccato or "chugga", especially when the Fuzz pot turned up high. If i play Strum->quiet->strum->quiet the circuit is really "breathing in breathing out".
I suspect that this is as it should be and somehow caused by the transformer?
Cheers
Edit: Sorry, i missed the 4-point form for the tech help board. Here you go:
1) Madbean Retrograde.
2) See *) above.
3) No steps really. I have re-checked the component values, but the question remains if this is really a "feature" or a "fault".
4) Nothing substituted.
Jean-Rock
Same problem, anyone can help ??
Jonny Rock the "French Canadian"
Affiliation : Jonny Rock Gear
http://www.jonnyrockgear.com
