Cherry Bomb!
Started by G.G., December 18, 2012, 03:49:37 PM
G.G.
Hi Folks,
Here's a little Cherry Bomb action for you. I've had this built up for a while now and finally got some decals on it. It's a great sounding circuit with a lot of range in the gain and tone controls. Unfortunately the distortion is kind of crackley on mid-gain settings. Putting in 2n3565's helped with that some, and sound nicer to my ear than BC109's. On Jon Patton's advice I put a Germanium MP38A in Q3 and that helped with the crackle quite a bit.  Sounds great on higher gain settings though, so I should probably just get used to using it that way.  Anyway, here are the pix:
Dude, that decal is awesome. It looks very 3D, like layered cardboard. Ever seen an old comic book/comic strip proof with the word bubbles taped on top of the pictures? Reminds me of that.
spaceboss
Nice job--beautiful pedal.
I like BC108s in mine. But as far as I can tell, I like them in everything. ;D
This pedal has become a workhorse for me. A Klon type circuit further down the line, set to low/no gain helps smooth things out in an excellent way if you are dealing with a bright amp.
J
G.G.
J,
Do you use yours on mid-gain setting?  I might have to swap in some 108s, I have never tried them. I really like the overall sound of the pedal and don't want to give up on it if there's a way to tweak out the crackle (which I suspect there is).
That finish is the bomb! People keep pushing the limits on things around here, I'm blown away like every other page.
Great job.
spaceboss
Quote from: G.G. on December 18, 2012, 04:48:21 PM
J,
Yeah, I run low to mid-gain most of the time, although I have the gain setting on the pedal maxed. I either roll back the volume or use a compressor set ahead of it to reduce the volume without using the compressor as a boost.
It could be that there's nothing special about the 108s and it's just the gain range of the ones I bought from small bear a ways back? but they seem to be lower gain with more body than 109s and the other suggested transistors. Also the tone controls on the CB seem to have a huge range. I keep mine with just a little bass (below 9 o'clock) and treble in the same range, with minor adjustments with different guitars.
There's quite a bit of boost on tap as well, so if you're using it as a boost, take care not to overload other pedals or amp in a displeasing way.
J
G.G.
I think transistor gain has a lot to do with it. I noticed a large reduction in crackle when I put in the lower gain Ge transistor so I might have to give the BC108s a shot. I'll try setting the controls differently as well and see what happens. thanks for the tips!
Quote from: G.G. on December 18, 2012, 09:00:51 PM
You need "A" range for BC's to get to hfe 100 or so. BC108C aren't very different from a BC109C, both will have over 400 hfe.
Or try something like a humble old 3904.
Finding in-production transistors with average gains near 100 is utterly ridiculous. >:(
I really like the decal work on this one. Like Jon said, very 3D!
Wow!  Great pedal, nice work
