EGO
Started by jeffaroo, November 23, 2012, 01:48:48 AM
jeffaroo
the 2 leds used for clipping...do they stay on or flash? do they turn on and off with the bypass?
i wanted to try to incorperate them into the case if i could
make a pic and leds will be eyes (balls...etc)
Not enough germaniums in this world to complete my wish list !
They will light up when you have them selected with the switch and only when the effect is engaged---not in bypass. So, you can wire them off-board and mount them to the enclosure just like you are wanting.
oldhousescott
...and only with signal applied. When you play, they should light. When you stop, they should go out.
