Small Bear 3PDT vs Mammoth?
Started by Beedoola, November 20, 2012, 08:25:19 PM
Beedoola
quite a difference in price. What Mammoth switch is the same grade as the ones offered by SB?
Depends, Mammoth sells different grades of switches. Which Mammoth switch do you mean?
GermanCdn
The "Pro" series from Mammoth would be the closest to the the Small Bear.
The ones for $2.45 (or whatever the quantity price is) are fine for DIY work and non production type stuff (in theory, if you were warrantying it to guys who might gig 5 nights a week with it, you'd probably want to spend a couple more bucks on a higher quality switch).  They're the same stuff as you'd get ordering from guys like PARTSPIPE on ebay, where the unit price typically runs a little under $2 a switch shipped if you order 20+.
Beedoola
Quote from: jkokura on November 20, 2012, 08:48:58 PM
like what the most expensive - I think $4.50 is the most expensive one mammoth has...
haven't made a direct comparison but...
Basically, the switches you get from Smallbear are made for Smallbear. Steve was one of the original importers of those switches that are made in South Asia. Since Smallbear started importing them, many other companies and suppliers have started importing them, there are now more manufacturers making various qualities of switches. For instance, the Cliff switches are made by the well known switch manufacturer Cliff, who make switches and jacks for Amp manufacturers often. You can get those Cliff switches from PPP for a little more than the taiwan clones.
So, all that to say, their all made overseas, and by various manufacturers with different specs. I KNOW the switches from Smallbear are great, however, I have used many switches of all the various grades from Mammoth and haven't had issues either.
I think Cliff was bought by CHK Electronics.
BraindeadAudio
The epoxy on those 2.45 switches at mammoth is spotty. Ive had a few bad ones.
The Tayda ones I got last time seem pretty good!  I only used Cliff in the past but have tried some others.
GermanCdn
The Tayda ones are fine as well, and they're 4PDT are actually quite nice.
I've gotten switches from Smallbear, Mammoth, Tayda, Ebay and groupbuys.
Rarely had issues (maybe once?) in at least 100 switches. So, at this point, price does not equal better.
For what it's worth, I just got a report today of a pedal I built for someone who took it on tour (to Australia!) with one of the cheaper Mammoth 3PDTs inside, and apparently it broke on the first night. At this point I don't know if something broke inside the switch, or if it got smashed on the way to Australia, or what, so I'm willing to chalk it up to bad luck. Still, I'm considering replacing the switch with a different kind once I get it back on the workbench.
Quote from: lincolnic on November 28, 2012, 05:31:32 AM
Urgh... that sucks!   :(  As a kiwi I would tend to blame Australians for that fault tho  ;) ;D
blakemoth
Make sure to let us know when something like that happens. Shoot me your info at blake@mammothelectronics.com, and we'll get you some new ones right away. I'll even toss in a sample or two of our Pro series so you can compare. We still stand by our normal Taiwan Blue ones, though.
Thanks!
insomniac2295
I haven't noticed any quality differences between the SmallBear switches and the Mammoth switches
Quote from: blakemoth on November 30, 2012, 07:18:31 PM
Thanks!
You're a good one, Blake. I'll shoot you an email now.
