Suggestions for new Mad Bean stuff.
Started by Mark0614, November 11, 2012, 09:07:18 AM
Mark0614
Here is the board for the Tonebender and I bought it, thanks Mad Bean, I look forward to receiving the board and building the pedal.
http://www.madbeanpedals.com/projects/Tonebender/Tonbender2014.pdf
Regards
Mark
Muadzin
I for one would LOVE to finally see some noise gate PCB's being released. You'd think that with those gazillions of dirtbox, compressor and boost PCB's being constantly released by everyone there would be some need for a noise gate to keep all that noise down.
mremic01
Quote from: Muadzin on October 19, 2014, 09:57:38 AM
Definitely. I built a Decimator/Engineer's Thumb combo and the two circuit work perfectly together. The Decimator keeps the noise out before the compressor can raise it.
GrindCustoms
Quote from: mremic01 on October 19, 2014, 07:27:54 PM
Compressor usually goes in front of dirt, noise gate goes after unless you like to hear the SSSHHHHHHHHH sound of stacked gain pedals when guitar signal is muted by the gate... putting a gate in front of the dirt is a bit irrelevant to me.
With the amount of Decimator i've built on etched layout i'd be the first one to have fabbed and available for DIY, unless some of pcb floggers gets a deal or consentement with ISP Technology, i highly doubt any of us will publicly release a layout, 100% sure we'll get sued.
Rej
Shrtyska9
Hey Rej what decimator layout are you using for your builds?
Richard
Richard
GrindCustoms
Quote from: Shrtyska9 on October 19, 2014, 09:26:17 PM
Richard
Gallego, can be found on DIYSB i think.
Shrtyska9
Richard
mremic01
Quote from: GrindCustoms on October 19, 2014, 09:12:20 PM
Rej
Depends on where your noise is coming from. I've had more luck with noise gates in front. It keeps things from getting amplified by cleaning up your signal early on. Yeah, a gate at the end of the chain will clean up anything generated by other stuff, but I've always had issues with the threshold settings either needing to be too high to turn off any boosts and not have it have weird decay problems, or not be high enough to deal with any noise getting boosted by pedals in front of it. In front of a compressor works for me, and keeps the compressor quite to boot.
GrindCustoms
I'd agree with that, pretty much depends of the setup. I always have a comp on, no matter dirt or clean and it's boosting a bit at the same time, that helps alot to control the treshold of the gate when put at the complete end of the chain.
There isn't a home-designed noise gate that works as well if not better?
Mark0614
Muadzin
Rej
Why? Plenty of other pedals get cloned and offered as pcb's. What makes the Decimator so protected?
Besides, even if the copyright gods do frown upon doing a Decimator pcb, why not use the MXR noise gate? It may not be exactly like the Decimator, but its been around for a while on the DIY circuit and something is better then nothing.
kothoma
Quote from: Muadzin on October 20, 2014, 01:11:54 PM
Most pedal circuits aren't patented, and can't be, but the Decimator is.
Justus
#28
IIRC, from researching the Decimator and G-string layouts a month or so ago, there are some corrections that are needed to be made to that build doc (Slade's G-string version).  The corrections and the build doc aren't an all-in-one, easy-to-read file though, and you have to comb through several forum pages to get it.  I'll attach a couple files that will help you figure it out.  (The corrections were derived from going through Galego's G-string schematic and finding where Slade's layout was incorrect.)
There is another layout floating around, not from DIYSB, that appears to be an original Decimator that incorporates a 3PDT switch and I/O jacks right on the PCB.  Very limiting on how you can lay it out, obviously.  The ground plane is a bunch of cross hatches.  I had that etch layout downloaded, but deleted it in favor of the corrected G-string version, and now I don't know where to find it again.
Muadzin
Quote from: kothoma on October 20, 2014, 01:31:32 PM
Seriously?  :o If its not possible to patent circuits, how could they do it with the Decimator? Especially since I came across two PCB vendors who were selling boards for it?
