Hybrid Amp Project (inspired by nzCdog's Lil Watter and Orange Micro Terror)
Started by Ettore_M, November 10, 2012, 11:10:28 PM
Ettore_M
Hi there!  :)
I'm quite excited today, because I discovered that all the boards are working! The pre-amp board causes a little hum, but it's not in a box yet so I think this will stop once I box it.  ;) BTW, with a 12AX7 at 100 volts, there is a whole lot of headroom available. Or so it seems to me!
However, it seems like an overkill having a full tonestack on soemthing like this. So I think I'll maybe get back to the Boobtube as a preamp stage.
The past days, the pre-amp didn't work, when I tried it in front of the TDA power-amp. Today, I tried it in front of my amp (like a pedal) and it works! So now, I think that this little thing needs more than 850mA that my 12V supply can give.
Also, the heaters are now working on 6.3 volts supplied by a LM317 and the tube doesn't get really hot and the tube will have a longer life. However, the LM317 does get really hot, even with a heatsink!
That's all for now! If there is someone with a little more knowledge than me on tube preamps, and wants to give an advice or two, you're welcome to chime in!
Hector
- Culturejam
Ettore_M
Holy F#%K!  :o
This thing works! I am surprised. The picture below shows why! ;)
It actually works. At least, I didn't expect it to behave well at all. But I got great sound from it. It sounds very tube-like, because of the tube preamp. And the TDA2050 gives a lot of power! I think it can get to volumes equal to my all-tube VHT Special 6!
However, I have a lot of noise..  :-\ I'll figure it out later. But as a proof of principle, I think this little amp can be a great amp project, and could be used, not only for practice, but for gigs too. I know a little optimistic, but with a mic'ed 12" speaker cab, you could cover the needs for a little bar gig.
Hope you can actually understand my words. I'm too tired even to think. I'm excited, though!  ;D
Here's a sample! It sounds like crap. I put the mic too far away from the cab, and there's an extreme amount of noise. But, I hope you like..  ;)
[soundcloud]https://soundcloud.com/ettore_m/hybrid-amp-test[/soundcloud]
Hector
- Culturejam
Very cool. Looking forward to seeing more of this. Looks like a fun project.
micromegas
Sounds really nice and I happen to need a new practice amp (my Mark II Boogie is to loud for home). If only the noise could be reduced somehow...
Software Developer @ bela.io
Ettore_M
Hi guys! I'm happy you like it. I'm going to fix some things that may cause noise, and I'm going to put it in a box, as now it's out and a circuit like this catches a lot of RF or 50Hz noise. I think it's gonna be just fine.
Note that the schem is not right as it is, as I changed a couple things. So, wait a little for the new one, if you wanna build one! ;)
Hector
- Culturejam
Ettore_M
Finished at last! And it sounds huge!  8)
I like it a lot. And volume-wise, I think it gets really close to my VHT Special 6! Pretty awesome!  ;D
I'll record a sample for you! I think you'll like it a lot too!  ;)
Hector
- Culturejam
gtangas
maiko
I know its an old thread but how did this project now.   did you update it?   Im very interested
