Moon Angel
Started by pickdropper, November 10, 2012, 10:16:08 PM
jimmybjj
Is c36 the power cap? I would be interest in seeing the other side of the board if you build another.
Pcbs no longer available
just ridiculously awesome
Quote from: jimmybjj on November 13, 2012, 02:35:17 PM
Yep, C36 is the 100uF power cap.  There is an identical one on the backside as well.  Next time, I am going to seriously think about using a 1210 non-polarized there.  Much lower profile, but it is about 2$ a cap, so I wouldn't want to use too many of those.
I do plan on populating another.  I'll snap pics of the backside when I do.
fish22
wow. That blows my mind. Just outstanding.
Your lazer etching stuff is so killer. Wonder if my local trophy shop could do that.....
Hi, my name is Wyatt.
That is the shit right there.
I think the 1590 fad can now end; this is as good as it gets IMO.
icecycle66
Quote from: raulduke on November 13, 2012, 10:54:59 PM
No, I won't let that happen.
$150 to the first person to get me a full pedal board in a mini-pedal.
How do I start a contest?
My requirements for a pedal board are, in order first to last:
Distortion
Flange/Phaser/Chorus (any one of the three)
Reverb/delay (either one)
Compressor
Must be able to use all the effects at once or one at a time.
Must be bass friendly.
Must fit in a 1590A or 1090NS.
Everything else is builders choice.
Srsly.
Quote from: icecycle66 on November 14, 2012, 12:13:39 AM
Distortion
Compressor
Srsly.
Well, I could get you the choice of effect, but not all at once, and not for just $150...
Distortion
Compressor
Srsly.
I think somebody else can take a shot at this one.  :-)
aballen
Distortion
Compressor
Srsly.
I don't even know of a verb that will fit in a 1590a, is there one out there?  outside that I have a 1590a for each bullet on the list.. but not in a single 1590a
studiodunn
That is a crazy sexy build, and the micro-soldering is just blowing my mind.
Quote from: aballen on December 14, 2012, 05:03:45 PM
Distortion
Compressor
Srsly.
I have been meaning to double check the brick size for that very thing, but haven't really been in any particular hurry because there are some really cool verb boards out there (albeit full sized).
Distortion
Compressor
Srsly.
Btw, which 1590a Flanger did you build?
aballen
Consider it checked.  The new small brick will fit.  I'm wondering if a mini rub a dub reverb might fit in there,  it has a small number of components... The layout would need components stacked under the brick or under the pots to make it work though.  SMT would work.
I just want to see a tiny pedal board with tiny pedals. That'd just be awesome.
Quote from: jimilee on January 06, 2013, 03:23:44 AM
I've been working on one for a while now.  I've got enough 1590A builds done, so I need to get around to finishing the board.
I've found the problem with the existing solutions from companies like Pedaltrain, is that the depth is really still designed for larger pedals, so I am going to do one from scratch.
