Just came into 3 busted DOD 680 analog delays....
Started by BraindeadAudio, November 05, 2012, 10:22:37 PM
BraindeadAudio
Need to repair em, I have one with an SAD4096, and 2 with the Reticon chips. Anyone ever work on one of these?   They seem pretty rad with the transformer and everything.
Also got about 6 Digitech Echo plus units all with different problems.
Guess Ill make this thread my troubleshooting in case anyone ever needs help fixing one.
Chat away! ;D
Are these the ones that were on eBay a month or two ago?
BraindeadAudio
Nah I got them as a comissioned repair along with the others out in austin.
BraindeadAudio
Ok, one of the units, the earliest one, has a bad power switch and the Normal/P.A. switch is missing. Board was crudely repaired by someone with what looks like a soldering gun and scorched the solder traces, will have to place jumper wire. 120Pf capacitor placement completely gone, Soldered between the 2 points as shown on schematic.
http://3.bp.blogspot.com/-jao2BMt3h6E/TrBE-MlkyiI/AAAAAAAAACw/O0yl3LAF77w/s1600/dod680.gif
Updates and gutshots coming once I replace the power switch and Normal/P.A. switch.
BraindeadAudio
#4
Gut shot after wiring it back up
Was making odd noise, traced it to a bad cap and replaced it and turned it on,
And we have a working unit!
Only thing is the AC wall plug has to be rigged to the power switch so I gotta get a correct power plug, but it sounds amazing.
I have to trouble shoot the other 2 units now because I had to salvage parts from those 2 to make this one a working unit, but at least now I have a base working model to repair them from.
Brian, this would be an awsome unit to make a board for!
Im sure most of the mojo of this unit is the unobtainable chips though.
If anyone sees one of these grab one! Theyre awsome
bigmufffuzzwizz
Great pedal. I was recommended one by a buddy and it really gets the job done well. I loved the unique spaceship sounds attainable from this pedal. Mine has a different silkscreen than yours pictured though. Do you notice a bleed through of delay when bypassed? Someday I'll have to switch it to a 3pdt...
BraindeadAudio
I have one with the other silkscreen, it also doesnt have the Normal/P.A. switch. I dont notice a bleed on the one I fixed.
According to a few sources these Reticon BBD chips are worth a pretty penny.
bigmufffuzzwizz
Thats probably the one I have, which doesn't have the normal/p.a. switch. What does that do?
BraindeadAudio
It seems to boost the signal a bit, i Am still figuring the unit out completely. It gets really buzzy and loud when that is engaged though hence why I think its a boost.
Is it possible that it switches the pedal to line level for use in a PA system, rather than instrument level for a guitar?
BraindeadAudio
that is entirely possible. That may make it work for a keyboard.
reedha
hey i have a 680 delay and it makes extreme white noise when turned on...any idea why and is it fixable? thanks
jwin615
Quote from: reedha on October 06, 2022, 12:18:59 AM
Start with any electrolytic caps.
I'm not familiar with the pedal but sounds like it's AC input, so should have a some power stuff going on. Start there.
