[non-madbean]: 4ms Atoner Ridiculousness
Started by MattOcaster, November 01, 2012, 08:52:32 PM
MattOcaster
What up guys,
4ms Atoner pedal from the audio mastermind of Dann Green at 4mspedals.com.
Here's the video:
http://youtu.be/IIwP3_YZEYQ
In short, it's a fuzz pedal (on tic ) with an LFO and Envelope to control the amount of "Atoning".
I still can't figure out how the hell one would use this pedal but at least it's quite a laugh! Smiley
The PCB is well made and all the pots are board-mounted which is nice.
I might add a graphic as well.
By error, I installed a 5V regulator instead of a 9V and surprisingly the results where pretty damn good.
The lower voltage changes the fuzz from splattery to more useable.
Really stoked with this discovery Cheesy
I'll add a voltage control when I'm feeling energetic! (it's not like it has too many knobs or anything!)
Kind regards,
Matt.
Check out my Blog :D
www.SonicTitanFx.com
DutchMF
That is one mother! Cool that you stumbled on something like a power sag without even knowing... Waht is that enclosure?
Paul
MattOcaster
It's a 1590DD - it just fits everything. The taller 1590D is usually used but managed to make the jacks fit.
monkeyssj1
awesome. i had a noise swash for a while. 4ms is great
