Warhead PS
Started by TNblueshawk, October 21, 2012, 07:52:35 PM
TNblueshawk
Hey guys, if I use a Road Rage ro run this on 18v, will that work?
In reading the BOM it seems to indicate that not enough current will be supplied ?
John
stecykmi
that's correct, but you may be able to use the LT1144, as it can supply more current before burning. although i don't know offhand if it's pin for pin compatible with the 1044 series (probably not, but shouldn't be too hard to perf a little circuit).
TNblueshawk
John
jimijam
lt1054 works as well just be sure to bend back pin 1.
TNblueshawk
Quote from: jimijam on October 24, 2012, 01:16:02 PM
Cool, if that will get it done then I'm in bidness! Thanks.
John
bigmufffuzzwizz
If you get this to work well for you please tell. I'm building mine right now and edging more towards using a wall wort due to the doc stating that there is more interactivity in the biasing trimpots compared to road raging it. Im sure you can still get a nice sounding vibe either way
