EgoDriver + GGG RAT With Demo
Started by dunwichamps, October 05, 2012, 06:24:39 AM
dunwichamps
EgoDriver + GGG RAT in a 1590DD enclosure
its EgoDriver into RAT, no switch on the order
Mods:
Added a Blend control on the Clip switch of the EgoDriver so you can do variable adjustment between stock clipping and the LED clipping. Super easy to do, just wire a 2k - 5k pot into the Clip 3 holes for the switch. At noon both clipping methods are somewhat out of circuit for a nice cleanish boost setting,
Added a Ross Mod on the RAT but made it different than usual. Its a 2k pot with one end wired to the normal 47 ohm + 2.2uF cap but the other end of the pot is wired to a 10uF cap with the middle lug of the pot going back to the circuit. Now dead noon is like least clipping with both caps mostly out of circuit. Turn it to the 2.2uF side and its normal RAT, turn it to the 10uF side and its a superbassy fuzzy RAT.
They stack really nicely, the EgoDriver can tighten up the RAT and bring out the mids/bite by just using it as a cleanish boost into the RAT.
Sigesmundninja
Wiring is beyond my belief! Very, very good job sir!
sgmezei
Straighten up those wires........
Awesome build dude.
Cool build.... awesome wiring :D!
MattOcaster
Neat wiring like this always rubs me the right way! :)
Check out my Blog :D
www.SonicTitanFx.com
dunwichamps
thanks everyone. Just a little bit of neurotic OCD and solid core wiring and you to can have that kind of wiring build.
bigmufffuzzwizz
Such a pro! Wiring looks great..Nice to see you here  ;)
