Leviathan - PT2399 delay with modulation?!
Started by kinski, October 05, 2012, 04:02:27 AM
kinski
I'd love to know more about this upcoming project! Is it based off the cave dweller?
I would love a 1590a delay with modulation!
No, it's closer to the Sea Urchin/DBD. The modulation will be fixed via resistors and uses a switch to turn it on/off. Alternatively, you can wire it so the modulation is always on and have a rate pot instead of the switch. Not enough room in a 1590A for both, unfortunately.
This one is actually already prototyped and is good to go, so I expect it will be in the next batch I have made. PCB size is comparable to the Smoothie.
kinski
kinski
Out of curiosity...when when your next batch be available? I'd love to get one of these boards when they come out.
It will be mid to late November. I expect the next batch will consist only of delay projects (Leviathan, Aquaboy and Zero Point) and then December will hopefully be the Harbinger and the FSH. Maybe the Moodring, too.
