Low Rider IC heats up.
Started by icecycle66, September 29, 2012, 04:21:48 AM
icecycle66
Problem:
IC 4 heats up.  It gets too hot to touch for more than a few seconds.  I'm tellin' ya, it gets really hot.  It gets hot fast, whether or not the effect is engaged.  I do not have a battery snap, I am only using a 9v plug.
None of the pots work except the octave up, it seems like it's controlling all the octaves and the clean signal but I can't really tell.
Things I've checked:
Checked for solder bridges.
Checked orientation of IC's and caps. The IC's are socketed.
Substitutions:
R15: from 24k to 22k
R55: from 160k to 150k
Mods:
I omitted C12.  I put a little wire jumper there, should I not have done that?
I switched C10 to 1n instead of 10n.
Do you guys need me measure anything specific? I didn't want to leave the circuit plugged in since it heats up whether or not the effect is off.
Is it in backwards? That'll cause what you're experiencing.
Quote from: midwayfair on September 29, 2012, 04:53:35 AM
He's said he's checked it but yeah, check again.
Those substitutions should be fine.
Something is orientated wrong or bridged in there though i'd have to say.
icecycle66
I took all the IC's out, then put them back in again.
Still heats up.
Om_Audio
Did you ever get this sorted? Hard to see from the photo but you might try a magnifier and examine the solder joints closely to be sure there are no bridges. I tried to get ideas as to where prob might be from the schematic but it's just a bit over my head. IC4 looks to be oriented correctly as do the trannys. Good luck!
C
dbharris
I think if you clip or desolder that jumper in C12 it should work.  See this post for reference: http://www.madbeanpedals.com/forum/index.php?topic=5622.msg48457;topicseen#msg48457
good luck!
-Dan
Wait, you jumpered C12? I thought that was a funny looking ceramic cap. Well spotted, Dan! [Edit: I now see that it's mentioned in the first post. Doh.]
Remove that jumper. The upper octave pot is connected to the +9v source, and C12 connects to ground. You've connected your +9v through the upper octave pot (100K reisitance max) to ground.
FWIW, I troubleshot one of these for literally months and to this day can't figure out what's wrong with that board.
icecycle66
#7
Alright.
I have been messing with it by doing stuff like put a new trim pot in, and changed ICs.  i put a new IC in slot 4 and it doesn't heat up.  Everything works (2 down octavoe is very quite, but I credit that to it being so low in pitch) now except for the Oct up.
I will clip the jumper when I get home and update accordingly.
icecycle66
Cut the green wire.  That did it.
Thanks guys.
dbharris
Really glad it is working for you!  Trouble shooting can be really frustrating.  I am trying to finish up my enclosure for a lowrider this weekend so I can box it up.  I'm really excited!!!
@Midway - I had an EA Trem once that would only act as a booster.  Took me a week of troubleshooting it like 5 hours a day to finally figure out that I had a bad SPST switch.  It always seems to be the little things.
-Dan
icecycle66
I'll be build reporting this and a mudbunny this weekend.  Featuring some Grind Custom special order boxes.
