New Kingslayer build
Started by Haberdasher, September 16, 2012, 02:58:32 PM
Haberdasher
True Byass Kingslayer built mostly to spec with one of my etched faceplates.  It uses the exact drilling template from madbean's build pdf (except for the LED placement).
I installed one of the 3pdt boards from raulduke (SJ effects) for the first time which was very nice to use.  It made everything very tidy!  Man, I could probably get used to that. 8)
I'm undecided on what chip to use in here.  Pictured is a tle2072 which cut down on the slight fizz I get with the tlc274, but the 274 seems to have a little more character.
It sounds great but something isn't right with my build. Everything else works, but the vol and tone knobs are not functioning.  The dual gang clean/dirt pot goes from clean to dirt but it's the only way I have to make it louder or quieter.  Got to do some troubleshooting with this, but wanted to go ahead and take photos before I tear into it. :)
cheers
FABBED PCB's FOR SALE:
Now carrying Matched JFETS
That might be my favorite etch of yours yet. Nice!
Love it.
I was actually thinking about doing the suicide king theme for that as well.  I don't think I could top that, though: the border is great.
Man, that's a beautiful enclosure. The board itself is really nice, too.
Good luck with the troubleshooting, I'm sure it's something simple. :)
jimmybjj
Pcbs no longer available
Deed J
Just a shadow in a Rock'n'Roll sky
Wow thats an epic etch and slick looking build... nice job!  8)
sgmezei
Dang! your etches look so badass!
sirbergersworth
Are you kidding me? That etch is top notch. And the inside? I have to start using those little switch boards.
"Comes a time when the blind man takes your hand, says, "Don't you see?"
-Robert Hunter
whitebread47
Damn, Keefe!   :o
I'm blown away by both the artwork and etch.  You're a class act!
Blake
"I don't think people are looking for the meaning of life as much as they are looking for the experience of being alive." - Joseph Campbell
night-B
Thats a fantastic build Keefe!
That etched front plate is  :o
Nice to see you are using the 3PDT PCB's and connectors I sent you too  ;)
Liustucru
Keefe, you'll always make me dream !!!
Perfect etch that perfectly fits your Kingslayer.
Longing for building mine.
Haberdasher
Quote from: lincolnic on September 16, 2012, 03:17:42 PM
Thanks man.  It actually turned out better than I imagined it would at first.
Quote from: pickdropper on September 16, 2012, 03:25:45 PM
Love it.
Thank you.  The outside border is actually the backside of a playing card but I got rid of the inset image and replaced it with the suicide king.
Quote from: midwayfair on September 16, 2012, 04:26:19 PM
Thanks Jon.  So far no luck troubleshooting.  I've confirmed those two pots are about the right value and the resistance is changing when the knob is turned.  I'm having trouble thinking what would cause them not to function in the circuit when everything else works.  :P
Quote from: jimmybjj on September 16, 2012, 04:35:06 PM
thats pretty awesome!
You are too kind bro!
Quote from: Deed J on September 16, 2012, 05:44:41 PM
Gorgeous finish, bravo!
merci
Quote from: nzCdog on September 16, 2012, 07:49:34 PM
many thanks
Quote from: sgmezei on September 17, 2012, 02:42:23 AM
thanks sm
Quote from: sirbergersworth on September 17, 2012, 03:39:46 AM
I was so used to doing it the regular way I had to make myself use it here but I have to say it made everything nice.
Quote from: whitebread47 on September 17, 2012, 04:20:53 AM
Damn, Keefe!   :o
Thanks
Quote from: night-B on September 17, 2012, 05:39:11 AM
Wooooow!
merci
Quote from: raulduke on September 17, 2012, 08:28:46 AM
Yes, thank you very much for that.  They are growing on me and I'm already thinking about using one again!
Quote from: Liustucru on September 17, 2012, 08:36:18 AM
merci!
Hmm...that's a stumper. Do you have continuity between lug1 of the Vol pot and ground? There's no change at all when you turn the Vol pot?
