Retrograde 1n34a's ??
Started by murdog47, September 06, 2012, 03:18:51 PM
murdog47
So I built two retrogrades, one for myself and one for a friend.  As far as I can tell they are identical with the exception of the 1n34a diodes.  One has a very nice pronounced octave and the other does not.  Could this be caused by using different 1n34a's?
murdog47
And voltages are almost identical on both.
Mike B.
Every Octavia I've ever built has a bit different level of octave mix. I attributed it to a combination of the inconsistent forward voltages of the diodes and transformer windings/core.
murdog47
I stared at the circuit last night after work and realized my problem! I didn't use a switch so I needed to run a jumper to get the octave instead of just the fuzz. DOH! Sounds great now  ;D You are right though, there definitely is a difference in the octave between the two.
