Question On LDR
Started by frankie5fingers, August 29, 2012, 03:36:31 AM
frankie5fingers
Hey All.  I planned on using a Parralax photoresistor but then found a Fender Vibrato LDR Optocoupler/Optoisolator.  The description reads:  Nonpolarized optical side has longer and silver dot, resistive side has longer leads and no dot.  I'm not familiar with this.  Can I/should I use this rather than the standard LDR from Mouser (or wherever) - any advantage?  Then... if so, how do I mount it (the 4 leads) vs the the two lead LDR?
Thanks, Frank
I could be wrong about this, but I think what you have is a Vactrol, not just an LDR.
The reason I suggest this is that four leads indicate that it's both an LDR AND an LED in one package, in other words, a Vactrol. That's why there's four leads - one for the the resistive end (light dependant resistor = LDR) and one for the optical side (LED).
TNblueshawk
I have an optocoupler I'm going to use in a delay that is very similar to that. I socketed it in case it doesn't do it for me and then I'll roll my own.
Google the data sheet on that and it will point you in the direction that you want to go regarding what lead to put in what hole.
John
frankie5fingers
Sorry for the delay in response.... damn day job.
I will socket it.  I have to believe that anything marked both Fender and vibrato has to find a home a trem, right?
I haven't bought it but I will and report whether or not it was a good choice.
Thanks, Frank
