EgoDriver Issue
Started by teknoman2, August 06, 2012, 02:49:55 PM
teknoman2
I finally built my first stompbox but there is a problem,
when I plug it in and I turn it on there is no sound...
When its off I can hear my clean from my guitar.
I upload some photos so you can see what is the problem..
teknoman2
teknoman2
Also when I turn it on the two diodes D3 and D4 doesn't light
instead the LED when I turn on the footswitch it works.
Sorry for my bad english and description.
teknoman2
Aslo I took the multi-meter and I noticed that the IN is grounded is that correct?
murdog47
Run a wire from the input ground (sleeve) to the output sleeve. When unboxed the output needs grounded. When boxed your enclosure grounds it for you.
murdog47
And your clipping LED's are probably working fine...you really have to crank it and dig into the strings to get the LED's going on this circuit.
teknoman2
Thanx mate I will try it
Hope it works.........
teknoman2
I just did it and it doesnt work
I connect them like this as you said,
Check the photo.
Am I wright?
murdog47
Yes that's correct....if you have a digital multimeter post some voltages at the IC pins and transistors.
teknoman2
teknoman2
At the Ic pins its 4.48 Volt at the transistors I dont have anything....
murdog47
4.8v at all eight pins? No voltage at the transistors is no good. Do you have an audio probe? I would recommend making one of these ( http://www.madbeanpedals.com/forum/index.php?topic=1140.0 ) You get the audio probe and can test your circuit before hooking up a 3PDT and jacks.
murdog47
If you have one start checking the circuit and see where you loose signal.
teknoman2
I had 4.8V on the 1-5 and on 4-8 so it is 9.6V if we sum them up.
What do you think is the issue??
Do you have any idea?
You should be reading 9v on pin8, 0v on pin4, 4.5v on pins 1, 2, 5, 6, 7 and between 3.5-4.5v on pin3.
