Deadringer switch connections
Started by Boom, October 29, 2010, 04:09:44 PM
Boom
Hey guys,
I´m finishing up on my Deadringer and now planning the decal. I´m having difficulty understanding which switch connections, according Brian´s drawing in the project file, on the DPDT are CC, FM, or VIN.
I assume the middle position would be FM.....anyone have an idea about the others ?
When you make the label, use the original Fulldrive pedal as your example. Label the switch like that. Then, it's a matter of turning the switch the right way inside. If you look closely to the documents, you should be able to follow which one is which - orient your switch the right way and it should be fine! If you get it backwards, leave yourself enough slack in your wiring to turn it so it's right.
giudis
#2
dwstanford
yeah, that's what you want.  you want an on / on, not an on / off / on etc.  you can even use a dpdt switch that's on / on if you already have one.
giudis
thanks dwstanford,
no, I haven't one! I will buy this!
thanks again
