2pin and 4pin transistors
Started by 2tonewarrior, July 31, 2012, 10:35:09 PM
2tonewarrior
Hi, I´ve recently seen several Ge transistors with two pins and four pins. Where is the missing pin in the 2-pin ones? and what the 4 pin are for in the others?
The first looks like this one http://www.techzonics.com/2ad149-germanium-transistors.jpg and the second one is this http://www.radiomuseum.org/images/tubephoto_klein/af138_1.jpg
Thanks
sgmezei
From what I have read the 4th pin is for grounding the case. Mine work without grounding it if that helps.
2tonewarrior
Quote from: sgmezei on August 01, 2012, 03:42:20 AM
Thanks!, good to know that. What about the 2-pin ones, anyone?
mgwhit
I read somewhere last night that the T0-3 format uses the case itself as the third pin!
2tonewarrior
Quote from: mgwhit on August 01, 2012, 04:06:57 PM
Thanks for the info, I figured it would be like, so the holes for the screws. Thanks you two!
Damn, every time i translate something with google translate it seems to me worst than if i would try to write it by myself.
