Fatpants v2 - T1
Started by HM, October 28, 2010, 10:50:39 PM
HM
hi the new version of fatpants not work for me, I can not setear While the T1, you can tell me how to do it, I find the right way.
the sound coming out is really weak in comparison with the version 1
The pots, 100kb and 10kb does not work well, reaching the maximum volume when in the half, then back down the volume
i used max 1044!!!!
is a simple design, but is driving me crazy and do not know why....
can someone help?
thanks
It sounds to me like you have a solder bridge somewhere.
Herman, do this:
Double check your part values - did you mix up any parts when you put them in?
Double check your part orientation - are any parts backwards?
Double check your soldering - did you miss any spots? Are any of the joints looking bad?
Double check your soldering again - are there any places that connect that shouldn't connect?
Take some really good pictures and post them here - we might be able to help you out!
HM
jacob appreciate very much your answer, you were right there was a track cut ...
Thanks again for your help!
pd. T1 17k is ok !
