Lighted Pot Board/3PDT Daughter Board Combo?
Started by tenwatt, July 20, 2012, 01:24:19 PM
tenwatt
Okay...I'm using three of DuctTapeRiot's lighted pot boards in conjuction with gtr2's 3PDT boards.  I thought I would hook one up and test it but I'm not getting the LED to light.  The LED will not light up.  Since the pot boards have a CLR I put a jumper over the CLR on the 3PDT PCB.  I'm getting a constant 9.22V from the power jack to the lighted pot regardless of the position of the footswitch.  If you click the switch on or off it remain 9.22V.  Bad switch maybe?
Not too bright....
mgwhit
#1
The footswitch doesn't control power to the LED, it controls path to ground.  I realize that doesn't fix your problem, but it explains the constant voltage reading.
I'm unfamiliar with DuctTapeRiot’s lighted pot boards, but have you checked to make sure your LED is oriented correctly?
tenwatt
Yup.  I've checked all the obvious stuff like wire orientation, LED orentation, power jack tabs, etc.  The only thing unique about this is that I'm using a violet LED.
Not too bright....
mgwhit
Did you happen to check that the LED works before wiring?  Maybe just a bad LED  ???
Josh
tenwatt
#5
Quote from: mgwhit on July 20, 2012, 02:26:16 PM
Is it a violet LED or an ULTRA-violet LED?
ULTRA-violet...
Quote from: gtr2 on July 20, 2012, 02:27:19 PM
No...no I didn't.  But after Matthew's last post I'm guessing I'm about to learn that I have to do something else to make UV LEDs fire.
Not too bright....
mgwhit
Some ultraviolet LEDs can be outside of the range of visible light.  It's certainly possible that this is just a wiring error or a bad LED, but I'd check the specs on your LED and see what wavelengths it emits.  Where'd you get it?
Take it in a dark room with something white and see if it glows :)
tenwatt
Pedal Parts Plus.  It says "LED T-1 3/4 3mm clear lens Ultra Violet in color. 2000mcd Forward Voltage (V) : 3.2 ~ 3.8 Reverse Current (uA) : <=30"
http://www.pedalpartsplus.com/mm5/merchant.mvc?Screen=PROD&Store_Code=PPP&Product_Code=5505&Category_Code=LO3
Not too bright....
tenwatt
Quote from: tenwatt on July 20, 2012, 03:13:02 PM
So does anyone know if this LED is supposed to be visible?
Not too bright....
mgwhit
I've been poking around the net off-and-on all day to see if I can find a definitive answer for you, but I can't.  According to Mouser, Kingbright used to make a UV LED  that emitted at 395nm, right at the edge of the visible spectrum.  Mammoth sells a Kingbright "Violet" that I have used and it emits plenty of purple light.  Kingbright's own site only used the term "Purple", which leads me to believe that they're trying to avoid the term "violet" altogether.  I have no idea if PPP sells Kingbrights, but it's a pretty standard brand.  Long story short: I've got no idea. ;)
I think Jacob's right -- you need to test it.  When it should be switched on, can you read any voltage across the legs?  If not, try connecting it directly to a battery (through a CLR, of course) with alligator clip leads.  If it won't light up like that, you need to swap it out.  If it does light up like that, you need to do continuity tests to figure out what's not properly connected.
Quote from: mgwhit on July 20, 2012, 08:40:07 PM
...I think Josh is right -- you need to test it....
Fixed. And seconded.
tenwatt
Not too bright....
mgwhit
Glad you got it working, and sorry I got us distracted on the UV tangent.  So is the PPP Ultraviolet LED just plain old violet?
tenwatt
I'm not sure.  It looks like a black light to me.  You can see some pics in the builds section.  I put them in a Wolfshirt/Snow Fox.
Not too bright....
