What type/brand/model POT is this?
Started by pappasmurfsharem, July 16, 2012, 05:29:45 PM
pappasmurfsharem
Obviously it is a B100K
This is the gain pot from my Vox Satchurator, it is unfortunately broken and just spins freely, and I would like to replace it.
I believe it is an ALPHA pot but I can't seem to find this one online.
pappasmurfsharem
That indeed looks pretty similar.
The shaft seems like it might be a little long though. Although pictures make it hard to judge
This is the actual part from Partsisparts (Vox's supplier)
http://www.guitar-parts.com/catalog/korg-pot-b100k-530000001046
It is Out Of STock, and I don't see any model number info
Sigesmundninja
After reading your alias a little closer I suspect you're swedish so...
Jag skulle nog chansa på att den funkar, i värsta fall kan du fila ner skaftet lite men jag antar att det ska sitta en vanlig "chickenhead"-knapp på och skaftet är ej för långt för dessa.
pappasmurfsharem
Actually I am American.
my alias = Pappa Smurfs Harem.
As in Pappa Smurf from the Smurfs. and his Harem (smurfette) ..... it is a very small harem
Using google translate I'm sure it would work it would probably mount the same. So as you said, modify it if need be.
Sigesmundninja
haha, my bad, offcourse the name means the same here :) didn't realise pappa spelled like that in english :) anyway, as I said, that pot will most likely work!
nimbleswitch
Unless he was gay. In which case it would be huge!
I've got one hand in my pocket, and the other one is waving a dildo.
