Unlabelled Component holes ROG May Queen
Started by Guybrush, June 27, 2012, 06:41:30 PM
Guybrush
I'm just organising my ever growing list of future builds and came across the Run Off Groove May Queen pedal.  It looks simple enough to build but I was just wondering what the unlabelled holes on the PCB are for?  I've seen them on other PCBs but never thought to ask.
a
Thanks.
If you look at the layout, those holes connect to other holes that are labeled: GND.
plesur
You can never have enough GND points.  :D
The other holes next to the caps are for using caps with different lead spacing.
Guybrush
I thought it would be a ground thing but the spare holes next to the caps threw me a bit.  Thanks guys.  If you follow the standard wiring diagram is there any need to wire up extra ground points?
