10.13 - Cupcake, Slow Loris, Zombii, Road Rage2, Neutrino and Sunking boards!
Started by madbean, October 13, 2010, 09:43:27 PM
Yes, replace the 47R with a 1kB for the Ruetz mod.
As far as that 51pF cap, it is to control the slew rate of the op-amp. The 308 lets you control this externally with a cap, and it is a feature which can alter the dynamics at high gian (which is what the Rat excels at). The slightly higher value was probably chosen to limit the slew rate a little more than a stock Rat, thereby limiting the response to fast changes in high frequency response (i.e. makes it a little smoother sounding).
More info: http://www.diystompboxes.com/smfforum/index.php?topic=16975.0
mjcyates
B_of_H
