EGODRIVER TANTALUM 1 UF OR 10 UF
Started by hnkyrocks, October 13, 2010, 05:05:35 AM
hnkyrocks
I just compare several schemes OCD ... there are 2 versions of tantalum capacitors are used ... is that using 1 uf, and in EGODRIVER use 10 uf. Which is better used to clone this OCD? 1uf or 10 uf?
thanks for your help...
HNKYROCKS from Indonesia
Do you mean for C7? In that case, either will work the same. There should be no tonal difference in using 1uF or 10uF in that position. The values are sufficiently high enough to let the full range of frequencies through.
hnkyrocks
yes...i mean C7 in EGODRIVER......because I was confused would be putting the best value in my EGODRIVER to position C7.....
thanks for your help mad.... ;) ;) ;) ;)
B_of_H
I like 1u tantalum better personally.
Haberdasher
Teach me something guys.  Is there some sort of an advantage to using tantalum?  I just put an electro there.
FABBED PCB's FOR SALE:
Now carrying Matched JFETS
Some people prefer the sound of tantalum caps over electrolytic....that's it, really. They also come in much smaller packages, which is a plus. On the downside, they appear to have a higher failure rate than electrolytic caps.
