Road Rage voltage conversion wiring
Started by monkeyssj1, April 19, 2012, 08:47:50 PM
monkeyssj1
Hey guys, so I'm about to put a road rage into my jmk op amp big muff and was just wondering.... If I connect the power supply jack into the positive 9v pad and ground pad next to it like it does in the wiring diagram of the road rage, where does the -9v wire go to? (board I assume?) Also, on the JMK op amp board, the 9v pad says +9v. This is why I'm a little confused. I hope I didn't confuse any of you guys with this explanation.
You don't need a road rage with Jacobs project.
Just use the wiring diagram here and you'll be fine.
http://www.madbeanpedals.com/tutorials/downloads/StandardWiring_MBP.pdf
Josh
monkeyssj1
lmao... sweet. that's a pleasant surprise. Thanks Josh. I'm really glad I put this in the newb section
