Road rage wiring question
Started by TNblueshawk, April 19, 2012, 10:34:58 AM
TNblueshawk
I was curious about when you would use the extra 9v and ground pads? Bean has those two labeled "to PCB or additional DC jack"
I'm running the 18v version of the RR but when would one use the above additional pads? Juat lookimg for examples for ideas I guess.
John
I suppose if you were running two effects in one box it could be handy. It's always better to have options  ;D
DutchMF
You could hook them up to a DC OUTPUT jack and power another pedal that is close by on your board. Check that you have enough mA's before you start drilling in your pedal though.....
Paul
The idea there was if you are running two circuits in one box, one with the RR and one at 9v, the extra pads would be wired from the RR to the PCB using 9v. That way you do not have to double up on wires on the DC jack because those stupid things have really small holes on their lugs.
TNblueshawk
Quote from: madbean on April 19, 2012, 05:13:58 PM
Awesome. No kidding either. I have a heck of a time just getting 1 wire let alone 2 and God forbid 3. I have thought about using a solder lug you use on amps for grounding and then you have one big hole but figured that is overkill.
Thanks guys.
John
