Neutrino popping loudly?
Started by add4, March 23, 2012, 07:23:26 AM
add4
I have just boxed a neutrino (my design, not madbean's same schematic, only sub is BAT46 for diodes), it pops loudly when the effect is turned on. I want to get rid of that.
What i tried :
- increase R1 to 3.3M then 10M -> no change
- Add a 10uF cap between the + and - legs of the LED -> no change
- change the switch -> no change
i'm short of ideas.. if anyone can help i'll be glad to try his/her(?) suggestion !!
THanks in advance
add4
the rules of electronics are strange ...
i closed the box so i could at least try it a bit even with popping, and... it doesn't pop anymore..
is there any reasonable explanation to that?
bangerang101
#2
Not sure what the cause was in your situation but for future refrence, theres a few other ways to get rid of circuit "pops" when engaging/disengaging effects.
Ive had good success in the past w/ the following methods to cure circuit "pops" (asside from the more well known methods)
- a 100k "pulldown" resistor from output to gnd will eliminate pop, in most circuits (assuming the circuit doesn't already have this pulldown resistor integrated into the circuit). To accomplish this, I ususally just solder the 100k resistor between the output jacks "tip" lug and "sleeve" (ground) lug.
-swap the input capacitor w/ a new/different one... the input capacitor can be the culprit for "pops" if it is faulty/bad.
- make sure nothing is touching against something where it is not supposed to (ie, circuit board touching metal casing on potentiometers), and make sure everything is grounded properly.
W/ those few tips, I'll bet you can eliminate pops 90% of the time. In some cases you just have to live w/ it though, if your using a mechanical switch (non-relay type switching), to bypass the circuit.
Owner of Luck Duck Pedals (LDP)
add4
Thanks for this list, i was hoping for something like that when i posted.
i copy pasted your answer in a file for future reference.
Thanks for your input.
bangerang101
Hey, no problem man... glad I could help!
