Latest Build using a Chunk Chunk board
Started by Chris McCullough, September 14, 2010, 09:31:32 PM
Chris McCullough
Chris McCullough
Cool image. I like the total disdain for 'naming' the pedal. Naming the functions in really small print is enough, and it looks mighty cool. Is the graphic from a cartoon you're a fan of?
Also, I hope your knobs are the 1/2" variety.
Chris McCullough
Chris McCullough
pauloman80
That is rad, man.  Nicely done.  I'm going to have to give those water slide decals a try.
Regards,
pauloman80
Chris McCullough
Chris McCullough
Chris McCullough
My son likes the cartoon Invader Zim. Zim is the one on the pedal.
Chris McCullough
Well executed design!  How about some gut shots :'(
eniacmike
can you explain your bias process for the trim pots? I have tried a few different ways and I still can't get a good sound out.
Chris McCullough
Whats it doing? I followed the destructions and then tweaked by ear.
Chris McCullough
eniacmike
oscillating like crazy, I either get completely clean sound or terrible oscillating crappy tone distorted sound. I tried 4.5v biasing and then adjusting from there, 1v biasing adjusting from there, pretty much every possible option and I can't get a good sound.
Chris McCullough
Make sure you have good solder joints. Make sure you don't any caps or resistors mixed up on the board. It is easy to get mixed up while putting this one together.
Chris McCullough
Did you sub any different values for your pots, mike?
eniacmike
no subs on the entire build.
I used the b5k potentiometer with a 5k1 resistor across lugs 3 and 1 for the mid control as it says in the instructions.
eniacmike
I did just find 1n4001 instead of 1n4004 maybe that is my problem?
Chris McCullough
Chris McCullough
