Pork Barrel - Good dry, but no chorus
Started by Comfort Player, March 20, 2012, 04:58:53 PM
Comfort Player
Buillt my Poker without any substitutions. I used the 3201 / 3207 chips.
I get a good bypass and when I engage the 3pdt I get the same a clean guitar signal.  No chorus effect.  My LFO is flashing.
Taking voltages on the ICS they look pretty much in line with other posts in the section except for the 3207.  My readings are:
1-0
2-3.72
3-4.04
4-7.45
5-0
6-3.63
7-0
8-0
I'm pretty sure pins 5 - 7 are not correct  :) but not sure where to look from here.
I have reflowed the socket and the jumpers and parts around IC4 but I am not really sure where to look ?
Silence..... I Keeeeeel youuuuuu....
DutchMF
I'm absolutely not an expert, but did you use the bias trimmer? My build had no chorus at all when fired up the first time, but as soon as I started twisting that trimpot....... WoW!! Just my 2 cents, you might want to wait for the experts.......
Paul
Comfort Player
Thanks for the tip, but I tried the trimmer.  No change to the signal.  Sounds the same as my clean signal.
2 & 6 seems fine, clock is going...
3 is okay, it has bias voltage.
5 should be voltage (8Vish) have you messed up the zener somehow?
7 & 8 should also have an output voltage... but fix pin 5 first.
Comfort Player
Quote from: Scruffie on March 20, 2012, 05:15:07 PM
I checked the zener and it is oriented the correct way. I get 8.10 volts on the side with the strip and 0.00 on the other pin.  I reflowed it and rechecked voltages on the IC and there was no change
I'd bet you have either a minute break in the trace or perhaps a leak to ground somewhere in there. Have you got some good pictures for us to look at for you?
Comfort Player
Quote from: jkokura on March 20, 2012, 05:45:48 PM
I can take some..Give me a few.  If I understand correctly, I should have current coming in in pin 5.  Where would that be coming from ? In otherwords what is the next component upstream ?  Looking at the schematic ( I am terrible at schematics ) it says out 1.1 ???? Not sure what that is ?
It would help me to know which Pork Barrel you're working with. Is it the latest one? A Manufactured PCB? A home etched one? Until then, I can't say for sure. Not to mention that Scruffie is probably the better one to answer. He's sort of our resident BBD expert round these parts.
Quote from: Comfort Player on March 20, 2012, 06:00:19 PM
I think that's a Typo, it should go to VD, so you are looking at C24, D4 & R40
You did install the jumpers on the PCB correctly yeah by the way?
Quote from: jkokura on March 20, 2012, 06:12:30 PM
Only the latest has the 8V2 Zener and 3207 option.
See... told you Scruffie knows best.
Quote from: jkokura on March 20, 2012, 06:16:58 PM
Haha, missed that part of your post, why thank you  ;D
Comfort Player
Sorry about that. The latest board bought from MB.
I see the VD section you are referring to.  I was looking at pin 5 on IC4 and trying to trace backwards from there and it is labelled Out1.1.
Pictures on the way as soon as I can get photobucket to respond  :'(
Comfort Player
Pics.. Board starting to get a uglier from the reflow's
Let me know if these are not good enough
Quite a few bad looking joints there... you should reflow.
What voltages do you get on the 3207 without it in the socket?
Comfort Player
#14
No chip in socket
1-0
2-3.68
3-4.05
4-7.45
5-0
6-3.6
7-0
8-0
when I put the chip in the only difference is
5=(-0.01)
7=0.02
8=0.02
Reflowing now, afraid I am going make it worse...
Should the jumpers under the IC have voltage ?
