Q-vibe Problem !
Started by Jimihendrix1987, March 19, 2012, 06:05:05 PM
Jimihendrix1987
Hi there,
I bought this PCB from the Great B long time ago, however I couldn't started with it since now. Today I've just finished it...
Problem? Only Bypass sound.
I've already checked the wiring around 5 times... But i don't know wtf it's happening... The lamp shines as it should and it vibes when I adjust the trimpots, also the intensity and the speed knobs (Outside LED does the same). So I think the modulation issue is solved...
Here are the voltages reading, I hope you could give me 10 hands ;)
Q1 (J201). D = 17v / S = 0v / G = 0v
Q2 (BC549c). C = 8.9v / B = 1.6v / E = 1.8v
Q3 (BC549c). C = 6.7v / B = 2.6v / E = 2.2v
Q4 (MPSA13). C = 17v / B = 3.1v / E = oscillation between aprox 0 and 9v
Q5 (MPSA13). C = 8.1 - 9.8v / B = 3.5 - 3.8v / E = 2.7 - 2.4v
There's almost nothing written about q-vibe...
I'm really looking forward to hearing from all of you, great builders  :D
Ignacio
Q1 Source appears to be a problem. Check for grounds there, and audio probe these two points:
Q1 gate to verify you have input signal
Q2 base and collector to verify you have output from Q1 and Q2.
Jimihendrix1987
Wow ! Solved !!!
It was a little piece of soldered jumper between q1's source and the ground...
Now it is working ! And how it works !!! Sweet vibrato machine  :o :o :o :o
Tomorrow I'll play with the trimpots a little bit, trying to get the best of this machine out.
On the other hand, I think we ought to improve the switch noise it produces between vibe and tremolo.
Is it possible to include a pull down 1 M resistor? Where?
Thanks Don Brian ! (in some Spanish villages, people used to call DON to wisemen ;) )
Jimihendrix1987
Can anyone answer this question ?
Thanks ;)
Jimihendrix1987
Quote from: Jimihendrix1987 on March 22, 2012, 10:12:17 PM
Thanks ;)
Eooo ! Has anyone suffered from a POP Noise everytime you wanted to switch between Vibrato and Tremolo mode ?
This POP Noise is exactly the same as you ear when you turn on your Rangemaster without a Pull-down resistor...
What can I Do?
Thanks
